It is currently Mon Jul 28, 2025 9:38 am
PostPosted: Tue Dec 01, 2020 1:58 pm
Before I just buy a new belt, maybe there is advice out there.
Several time recently, the edge of the belt has dug into the wood being sander and continued to cut in deep slots. This is as the wood is moved across the belt. Fortunately, these were just cheap pieces of wood for projects around the house.
The belt seems OK and properly tensioned.
Any advice?
PostPosted: Wed Dec 02, 2020 3:02 am
At the risk of sounding over simplistic, maybe just don't touch your workpiece to the edge of the belt? I have a 6x48 and I pretty much just sand things that are only as big as the Platten or maybe longer. I recently got an edge sander to help with bigger pieces.
These users thanked the author Pmaj7 for the post: wbergman (Wed Dec 02, 2020 12:17 pm)
PostPosted: Wed Dec 02, 2020 10:17 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Simple things first: Try a new belt. If problem goes away, fix is found.
Peter Havriluk
These users thanked the author phavriluk for the post: wbergman (Wed Dec 02, 2020 12:17 pm)
PostPosted: Wed Dec 02, 2020 10:43 am
Last Name: Colbert
City: Anacortes
When you replace the belt buy a decent quality one!
I have really good luck with the Klingspor brand. The junk that Grizzly sells curl up on the edges immediately and the seam isn’t smooth.
Good luck
These users thanked the author Michaeldc for the post (total 2): wbergman (Wed Dec 02, 2020 12:16 pm) • Pmaj7 (Wed Dec 02, 2020 11:05 am)
PostPosted: Wed Dec 02, 2020 11:04 am
industrial abrasives in reading pa is where I can by belts
and as mentioned above stay off the ends of the belt they will dig in
These users thanked the author bluescreek for the post: wbergman (Wed Dec 02, 2020 12:16 pm)
PostPosted: Wed Dec 02, 2020 12:41 pm
Belt sanders can cut a groove whenever you get the wood on the edge unless you're very careful. It's quite difficult to use a belt sander with a piece of wood that is wider than the belt, you have to keep the wood moving all the time and use very light pressure. I've done it but no longer try, it's more work than it's worth and even then it isn't always successful.
Of course, as others have said, it's important to have a good quality belt.
These users thanked the author SteveSmith for the post: wbergman (Wed Dec 02, 2020 3:09 pm)
PostPosted: Wed Dec 02, 2020 2:52 pm
Have you had good luck using the belt sander in the past without it digging in at the edge? If you have you could try tearing a quarter inch off the edge of the belt. Cloth sanding belts will usually tear off pretty uniformly, but not always, so this is kind of a last ditch effort. A torn edge won't be quite as "sharp" as the factory edge and may be less inclined to dig in.
These users thanked the author Clay S. for the post: wbergman (Wed Dec 02, 2020 3:09 pm)
